I have hung two fluorescent fittings in the loft space by running 1.5 lighting cable from one to the second one what must I do now to power the lights up will I need a junction box
where on the drawing it says "to next light" that is where you connect the cable to your loft lights.
at a conveiniant point you put in a switch (cable goes in and out, from exisiting to new lights)
in the switch you connect the red to C (in) and L1, (out) also the earth to the earth termianl of the patress
then up to the first light
this light you connect it as normal
you then run a cable from the first light to the second and connect as normal
(i believe you have done this bit already)
at all places the earth should be covered with green/yellow sleaving
switch mains back on, and go into your loft press switch and admire your handywork, send me 80p, and do not step backwards as the loft hatch will still be open
