Long handeled pz3 screwdrivers
16 Jul 2009
Hull
Any one know were they sell long handled (300mm plus). Pz3 screwdrivers? Screwfix only seem to sell them up to 150mm. Thanks
well a long reach one as doesn't this give you move leverage?
Leverage?
A screwdriver is not a lever.
It unscrews by applying rotational force called torque!
Leverage?
Leverage?
i think he was pointing out length does NOT give any advantage like a lever
ok i am now confused as those comments you where responding to where fallouts comments :LOL:
Some screwdrivers have a hex section on the shaft or hole in the handle. Any force appled to these would be leverage :p
If I need an extra long shafted screwdriver with extra torque, I'll use a 3/8" screwdriver handle or 3/8" drive ratchet, various extensions and a magnetic bit holder that'll take any standard sized bits.
i made a 250mm long extension from a length off hex that was the depth stop for a drill
bashed out the hex on a standard extension bar and hammered the end to be a tight fit on bar
