Looking for a rubber clamp with an eyelet.
Discussion in 'Tools and Materials' started by gerbils, 2 Dec 2019.
  1. gerbils
    gerbils
    2 Nov 2016
    59
    Thanks Received:
    Country:
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    23,246
    Thanks Received:
    4,518
    Northumberland
    Country:
    Does this device have to solidly clamp onto the tubing, Mr. G or just slide?
    If its just for location, maybe a 'P' Pipe clip would suffice.
    John :)
  4. gerbils
    gerbils
    2 Nov 2016
    59
    Thanks Received:
    Country:
    Unfortunately needs to be 100% a solid fix.
  5. foxhole
    foxhole
    14 Mar 2006
    18,243
    Thanks Received:
    2,094
    Kent
    Country:
  6. Sponsored Links
  7. scbk
    scbk
    22 Dec 2012
    928
    Thanks Received:
    174
    Ross-shire
    Country:
    Scaffold fitting and old inner tube :censored:
  8. mattylad
    mattylad
    27 Apr 2008
    8,428
    Thanks Received:
    646
    Country:
    What is it being used for?
    supporting a picture frame or holding your weight?
    Knowing this helps someone know wtf they are looking for - something plastic or something much better made.
  9. opps
    opps
    16 Jun 2006
    5,424
    Thanks Received:
    884
    London
    Country:
    • Thanks Thanks x 1
  10. Tigercubrider
    Tigercubrider
    22 Jul 2016
    4,787
    Thanks Received:
    772
    Country:
    http://www.doughty-engineering.co.uk/shop/21/index.htm
    If you are lifting or suspending any load then you MUST use fittings that are designed and certified for the loads. Unless this is a home diy you are subject to LOLER regs
    A bit of innertube can be used to stop metal marking metal
    Or use a flying strop with a specified loading
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
