Hi folks can you help""""""
Recentley installed 6 rads 1 unvented cylinder and a pellet burner.
Pressure gauge reads 1 1/2 bar. It all runs great for about 4 hrs until low water pressure k noks it all off and filling and venting has to take place to resume working.All pipework and fittings can be seen and no loss of water is seen.
My question is i have a automatic air vent on the coil flow in the attic, if any unvented air gets up there and is expelled by the vent will this be enough of a loss to cut the safety controls. If so will this get worse and worse and eventually boil or flash the boiler water.
Should the vent be changed to a manual only to be used upon filling thus making it a completely sealed system
Many thanks
Many thanks
