Low energy light bulbs or WATT?
definatly best to check if your not shure :D :D :D
look a bit silly or burn the house down :roll: :roll: :roll: :wink:
An angle that I'd previously not considered that someone alerted to me recently is that while an 11w CFL gives off a lot less heat than a 60w filament lamp, using the CFL as a replacement in an enclosed fitting might give issues due to the fact that the CFL will still give a reasonable amount of heat and while the fitting won't suffer (having been designed for a 60w filament lamp) the CFL may do as it contains electronics rather than just metal and glass, etc
(its a potentional issue wherever a CFL is used in an enclosed fitting, not just for 11w in place of 60w, etc)
I must add though, that I've not seen one die from this though, and even if it did I probably wouldn't know about as I don't record the operating hours :lol: anyway they are cheap enough not worry about it failing too quickly, much the same as we always did with filament lamps, other than I suppose from the POV of the amount of mercury ending up in the landfill in the name of green....
Adam, on a similar angle, one would expect the electronics to last longer in a CFL pointing upwards, due to the electronics being at the base, and any heat in the lamp dispersing upwards. :wink:
Ah but.... in our ceiling light fittings which take two regular 40w bulbs, the lamp is horizontal as opposed to vertical, so maybe this would make a difference in terms of electronics and heat dispersal. Fascinating though this subject is, I think I'd better call it a day and just get on with changing light bulbs for now, but I can honestly say that it the debate has been an enlightening experience[/b] :wink:
Actually, forget the last comment as I realise that it's exactly the same principle, regardless of whether the CFL is vertical or horizontal. Sorry! :oops:
