Low Pressure on Triton Topaz T80i
4 Jun 2004
Hello all
I have a Triton Topaz T80i shower. For the last few weeks, the Low Pressure LED has been coming on after using the shower for say 5 minutes. The Low Pressure LED would only go off if the temperature was turned down. Over the last couple of weeks, the problem has gotten worse and worse, ie. the temperature at which the shower could be used got lower and lower. Now, the Low Pressure LED is permanently on!
The water pressure does not appear to be the problem and the shower works perfectly well otherwise, i.e. a strong jet of lovely cold water.
Does anybody have any ideas? Heating element in the can? A diagram of the unit is attached below.
Also, can anyone tell me why the shower was plumed onto the hot water rather than the cold water? The hot water is provided by a combi. Is it common to plumb showers onto the hot water when heated by a combi? In my case, it seems completely impractical as you cannot set the temperature of the hot water on the combi, i.e. the shower is always burning hot if the boiler is on.
Thanks :roll:
Should NOT be installed to hot water but directly to mains
Was the name of the installer John Wayne??
Get this sorted but I think the shower made be kaput as the hot water from the boiler may have boiled it
Thanks for the reply.
I never use the shower with the hot water on, so overheating is not the problem. I've only recently moved into the house, so I can't say for sure whether or not JW was responsible - but it seems to have his hallmark! Very annoying having to turn the HW off every time you want a shower.
I know that the shower is kaput - I can tell that from the temperature of the ice-cold water. What I need to know is what part to replace. Any ideas?
Thanks.
For the price of these showers nowadays
you are probably better of replacing it all.
agreed any plumber will tell you these are disposable units and repair is rarely worth bothering about, that said however the technical desk at triton will listen to your problem diagnose it over the phone and sell you a replacement part.
I have no idea how it can be plumbed into the hot water supply from the combi and then come out cold at the shower though when your boiler is ok.
As I said, I turn the boiler off whenever I am having a shower.
I guess that's topic closed.
