Were "Kablo" (if that's the same, or related) not responsible for the previous wide-scale cable problem - or is my memory failing me?I found the manufacture of the cable. http://www.sevalkablo.com/m/products_en.asp?id=16
Kind Regards, John
It's just occured to me that 'Kablo' is probably just Turkish/whatever for 'cable', so that 'Atlas Kablo' (responsible for 2017 problem) may well be totally different from 'Seval Kablo'!Were "Kablo" (if that's the same, or related) not responsible for the previous wide-scale cable problem - or is my memory failing me?
Wasnt that an issue with the copper content, surely that would not affect insulation resistance
Yep was a fire hazard when in fault
That's certainly a possibility.It sounds like something similar has happened again with cheap Turkish cable - this time they have used substandard plastic for the insulation, maybe the plastic was recycled and mixed with burnt PVC, which is conductive would be my guess?
Sorry for butting in but look at the other end of the real, the two conductors are exposed and very close together. I would slice that end open to separate the wires a bit.Well just grabbed a reel and done a test on it. Guess what 58.2M.
If you did read the rest of the thread, you would see that that has already been suggested.Sorry for butting in but look at the other end of the real, the two conductors are exposed and very close together. I would slice that end open to separate the wires a bit. ... PS. I have not yet read the remaining 7 pages of posts
While it only goes up to 20M, a Calcard would pretty well eliminate that question. Moot though it is now the cable has been fingered as faulty.However, if it is able to display >999 MΩ on some cable (and also, presumably, if you don't connect the test probes to anything) then, despite my initial thoughts, I'm now far less convinced that it's going to prove to be a meter issue.
