Hi can someone recommend LV Halogens spots (polished chrome) that can be used above a shower and the rest of the ensuite room. I think I'll need 4 or 5 spots.
There are 1,000,000,000,000 manufacturers of these sorts of lights.
In a bathroom they must be rated IP44 or IP65 if they are liable to have water jets spraying at them.
This may help http://www.niceic.org.uk/downloads/Pocket Guide 1.pdf
I will bore you with a small but important detail - electrical work in a bathroom is notifiable and must be carried out and certified by a competent person (see the WIKI). From your question I'd respectfully suggest that you should not be doing this.....
