- Joined
- 27 Jan 2008
- Messages
- 29,626
- Reaction score
- 3,661
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It looks like a plain tordinal transformer in which case yes I would assume quite heavy? The lighter versions are not simple transformers but also have electronics inside and often a minimum as well as maximum output those will not work with LED.
The replacement I linked to is also a simple tordinal transformer and you could use LED lamps.
But if you replaced with one of these
then the minimum size of bulb is 50W and you could not use LED bulbs.
