I have got to lower the ceiling in my bedroom and i would normally use s set of joist hangers and use 100x50mm joists but the problem is that one of the walls is plasterboard. room is 12ft by 9ft
I was thinking of screwing a batten to the joists in the plasterboard wall but i am not sure it will hold especially with the woood at 50mm wide.
Also how far apart fo you nornally set your joists? I was going to do them 3ft apart is this correct?
And finally does it matter if you can't get wood long enough for the whole room? i was a bit concerned about making a join in the wood if one piece wasn't long enough.
Any help with this would be really appreciated and sorry for the long mail.
Phil
Phil
