Confession time...after a LONG delay I'm finally actually getting our new aerial up with T & K brackets and using M10 (16mm hole) Shield Anchor Bolts (see previous thread ...//www.diynot.com/forums/viewtopic.php?p=821141#821141).
Rather than resurrect the old thread can I ask the specific question about the M10 bolts I did finally decide to use. (Rawlbolt M10 which need a 16mm dia hole drilling in the brick. http://www.tlc-direct.co.uk/Products/FXRBM10.html ).
I've successfully drilled the holes (thank goodness for SDS drills!) and inserted the bolts with the T & K brackets in place. I have tightened up the bolts sufficiently to hold the brackets fairly firmly. It is clear though that I could tighten them up a lot further with a spanner, but I'm concerned that because of the way the bolts work I could expand them too far and split the brick. The bricks are reasonably good quality facing bricks. I saw somewhere that there is a recommended pressure using a torque spanner, but just wondered whether you have any tips for a DIYer without a torque spanner.
Incidentally I paid about £1.60 EACH for the ones from TLC, but I see screwfix are doing similar for £2.08 for a pack of FIVE !!!
Anyway I promise to update the board on the success or difficulties when I finally get this thing up! Hopefully in time for the Olympics.
