So my boiler was dispensing hot and cold dhw and had sprung a leak. Found the leak to be coming from the plate heat exchanger. Not long finished putting it all back together (had pcb out to find leak) and boiler won't turn on at all. Dead. Mains fuse is ok, so is one on pcb. Power going to the switch on user controls but when I turn it to on, not a thing :/
Anyone any suggestions on how to narrow down the fault? The instructions that come with it are useless.
Thanks in advance!!
One other thing. Opened up pcb for a check and there a load of brown stuff (solid) coming from a blue block. Don't know what it is or if it's affecting it)
Thanks in advance!!
