Any recommendation on which manufacturer?Used correctly and it should give good service. If it's possible, fit a full bore drain valve rather then just capping off the drain of the unit.
Mine was from Screwfix. Fitted by me in 2004.
Turboflush.
As it happens, it's the first one that shows when you search on Screwfix site.
You can see from the picture, the drain option showing at the left side, bottom. Try to fit a full flow drain rather then just capping as shown.
From that pageThanks for that. Actually I found one quite a bit cheaper than Screwfix:
http://www.buyaparcel.com/p/macerat...cerator-pump-t11-for-wc-toilet-and-basin-the/
Turboflush T11 Macerator Pump Watereasy 500w For WC Toilet and Basin – The Turbo Flush Replacement
Actually you have a good point. Several sites say that the Turbo Flush has been replaced by WaterEasy" which they claim to be a Saniflo product. Looking on the official Saniflo website at current proiducts, there is no trace of WaterEasy, but then Turbo Flush doesn't appear either.From that page
The spelling of Turbo Flush is changed to Turboflush so not the same trade name.
The Turboflush is a replacement for the Turbo Flush.
Are you sure you are getting a genuine Turbo Flush or are you buying a cheap imitation. It could be a Turd No Flush
