Mains wiring a smoke detector
13 Nov 2006
Liverpool
I'm looking to put a smoke detector in which is mains wired via the existing light loop. Can I simply link it into the existing light loop by taking a two core and earth cable from an exisitng light to the smoke alarm, and then take a two core and earth cable from the smoke alarm to the next light in the exisitng loop...? The lighting loop would then be
light -> light -> smoke alarm -> light -> light
with each -> being a 2 core and earth cable.
Unless you want to interlink several smoke alarms.
In that case you run T&E from lighting circuit to first alarm then you need to run 3 core & earth cable from the first alarm to each of the linked alarms.
Two of the cores provide the power (live & neutral) and the third wire carries the interlink signal so if one alarm goes off then they all sound.
TTC
Thanks for the advice, but I'm still a little bit confused. I've drawn 3 diagrams as to what alternates I can think of. If you could say 1,2 or 3
1. light --> light --> light --> light
...............Smoke Alarm
2. light --> light --> light --> light
3. light --> light light --> light
.................Smoke Alarm
where --> and \ is Two Core and Earth cable.
Ignore the ....... as they are just there for spacing.
Cheers
Swedge
I would go with diagram 1, personally.
Are you planning on just having one smoke alarm in the whole property?
