1.5 t&e , whats the highest rating cb it can take in normal wiring conditions no insulation?
geezer said:1.5 t&e , whats the highest rating cb it can take in normal wiring conditions no insulation?
10.8kw shower circuit.Pensdown said:Just out of interest, did you have a specific requirement?
Does this include underfloor heating?crafty1289 said:10.8kw shower circuit.Pensdown said:Just out of interest, did you have a specific requirement?
these pesky DIYers![]()
dont be silly, that needs 2.5mm² cable at least!Spark123 said:Does this include underfloor heating?crafty1289 said:10.8kw shower circuit.Pensdown said:Just out of interest, did you have a specific requirement?
crafty1289 said::Pensdown said:Just out of interest, did you have a specific requirement?
kai said:1.5.sq.mm. cable can safely take 13amps loading, as it can safely be used to feed socket outlets from fused spurs fed of a 13amp fuse-connection unit.
See the onsite guide - it states that 1.5.sq.mm. cable is an allowable size on a 13amp fused spur off a ring final circuit.
