I have already searched this forum looking for help. I found lots of related threads here =
https://www.diynot.com/diy/search/75855794/?q=nothing+plugged+in&o=relevance&c[node]=8
But I am still stuck and need help.
A bit of background: I own a flat (ground floor and basement). I lived here previously years ago and had no problems with the electrics. Then I rented it out for 5 or 6 years. I moved back in last week. The 15 amp fuse (old fashioned. Fuse wire) blew 4 times on the first day. Then blew a couple of times during next few days. I paid to have a modern fuse box installed a couple of days ago. Ever since then the MCB keeps tripping and on occasions the RCD tripped too. The electricians who installed it came back yesterday. And waited around expecting the MCB to trip again. Which of course (sod's law) it didn't. They seemed unable to think of what other tests they could do. It was left that I would try and diagnose the problem myself (ie try to identify what socket or device was causing the problem) over the weekend. The whole flat is on just one 15 amp ring circuit. After many hours of only using electricity in certain areas it dawned on me that the MCB trips even if nothing is plugged in.
I contacted the previous tenants who said they never had any problems with the electrics.
Reading through all posts that seemed to have similar problems I can already say ... I have not been drilling into walls or hitting nails into walls to hang pictures. Also there are no power sockets outside.
Does anyone have any bright ideas that could help me?
At the moment I am coping by running a couple of extension cables from the cooker plug.
One other (curious) thing that might not be related. In the lounge there was a double socket that was dead. The electrician pulled up some floorboards but could not trace the route fully but said it seemed to be on its own isolated ring/circuit. Apart from the cooker circuit the rest of the flat (ground floor and basement) is all on the one circuit. So it seems strange to me that there should be just be a random socket on its own circuit. He took the socket off, 'capped' off the wires and screwed a plate over it.
Any bright ideas anyone?
