If i install a new circuit for a kitchen oven, should i use an RCD or MCB.
For the record, and with respect, this post is ill-informed and should be ignored.as far as im aware everything should be rcd protected and even rcbo protection mcb s will be a thing of the past i reckon
dont slate me im not an expert in elecs just putting my view across
Hi Taylortwocities
I will use a electrican to complete the job but what is the answer as i am curious as to why two types of similar safety devices offer different protection. What advantage does an rcd have over an mcb. The earlier posts seemed to indicate you could use either
thanks bs i would appreciate what should be ignored if not all and why surely there is some current regs in there or am i misinformed terribly bearing in mind i did make sure i posted as a layman or amateur as you will perceive me cheers for the reality call
OK, briefly... Every circuit requires its own MCB to protect the circuit cable against overcurrent. Additional, to the 17th edition regulations, most domestic circuits require an RCD to protect people against conducting currents to earth through themselves. RCDs are common to several circuits, so an earth leakage fault can switch off more circuits than necessary which can be dangerous. An RCBO can provide the functionality of both MCB and RCD and an earth leakage will only switch off that one circuit. So the RCBO is the preferable solution, and will be more common when the price becomes more sensible than it is at the moment.
