MCBs for cable attachment. not busbar.
27 Aug 2003
London
I need a couple to go in a generic enclosure - are there any makes I should avoid which don't have cable entry points behind where the busbar would go if they were in a CU?
You mean the likes of the old wylex where the screw went through the busbar? Crabtree starbreakers, Square D KQ/SQO/QOE - (you maybe able to remove the pickups from the KQ/SQO)
All I can say is that I have fitted an extra (modern) MK MCB to the old style Sentry Unit, using a kit supplied by MK. With this kit, I fed the MCB via a flexible cable link, rather than a solid busbar. It worked very well.
What are you trying to achieve?
Don't you need isolation at that point (ie DP main switch)?
No - if I look at, for example, a Siemens or MK MCB, there's a box terminal about 2cm behind the busbar slot. The screw which clamps onto the busbar also tightens the box terminal, so you could use either to supply the MCB.
Ban - as you point out, many MCB's have both a box terminal and a slot.
The busbar design determines which is used to attach the MCB to it.
I would say with almost certainty that if your MCB has a box terminal, it will suit attachment to a cable.
Indeed - hence my Q (rephrased with a different term): are there any makes I should avoid which don't have a box terminal behind the busbar slot?
worth checking the short circuit capacity M rating,stamped on the mcb merlin gerin pretty reliable (M4.5 I think) and have no busbar slot.
Personally dont rate proteus.
I can't think of any modern domestic breakers (apart from some Square D, Merlin Gerin & Crabtree Starbreaker, which can all have a "stablock" method of attachment).
However, many older breakers (in the days when busbar design was far more individual) don't have box terminals.
You mounting on a rail?
Not fussed, as long as it's reasonable. I want a 30mA RCD, 2xB6 & 1xB16, and for no reason other than anal retentiveness I would prefer the same make for all 4 - was going to trawl eBay...
Hagar is always the choice for seperates - Their RCD's being the cheapest would also swing things.
The Wylex ones (New Type) on my CU have a large terminal at the top and bottom, as they clip onto the din-rail, and the pin of the multi-pin busbar sits inside the lower feed terminal of the breaker. Alternatively they can be wired cable in and cable out if needed. :lol: :lol: :lol:
