Hi All,
I’m fitting a new 25mm MDPE water main into my property under UU’s lead replacement scheme. Does anyone know if you can get a suitable MDPE drain off valve fitting? All I can see is copper!
You seem to be able to easily get hold of MDPE stopcock’s so can’t understand why MDPE plastic drain off valve shouldn’t be available also. This would avoid me having to use copper compression stock cock and drain off and then switching back to plastic barrier pipe (15mm) inside.
Thanks in advance for your time.
