- Joined
- 19 Aug 2015
- Messages
- 2
- Reaction score
- 0
- Country
I have had a problem with my hot and cold water flow, and I've just rung my regular plumber but sadly he's now retired. The water comes from a borehole/filter, and enters the property pressurised at 4 bar - have had this checked and serviced recently to eliminate that as the source of the problem.
The system I have is an unvented Megaflo, so I've researched it and emptied/refilled the h/w tank as per the instructions on the side. This has solved the h/w flow - which is now very strong - but the cold water flow is still poor. There's no discolouration and the taps have an initial burst when opened before quickly waning. On the downstairs kitchen tap (the megaflo is upstairs) the rate is approx 1 litre per minute after the initial burst.
There are no obvious leaks or drips anywhere and the tundish is dry.
I'm a bit baffled as to why the hot flows ok now but not the cold; looking at other threads I suppose it's because the tank has been re-pressurised, and once empty that flow would dissipate.
Reading up on it, it seems the one thing I can do while I find a reputable plumber who will come out to rural Devon, is to clean the strainer on the cold water valve set. Mine is an older part (#95 605 869) with a plastic cover secured by 4 allen head bolts. So...
Could this possibly be the problem?
And is this something that just a punter like me should be doing?
And if so, how?
Any advice would be hugely appreciated.
And if so, how?
