Hi, Can someone help with advice.
I am looking at having an additional consumer unit installed in my cellar. It will be approx 8meters from the meter and main board. The main board has no spare ports on it.
I will be having an electrician in to do the work but would like to do as much of the 1st fix as I can to help keep costs down.
What items would I need to do this. I have got a RCD Consumer Unit, what size/thickness tails would I need. Do I need to install a mains switched fuse as the tails will be about 8 mtrs long. They will be fixed in surface mounted trunking so no cables will be in walls or ceilings.
Hope this makes sense.
Phil
Phil
