Micro bore central heating
20 Mar 2005
I have micro bore central heating and two of the radiators are cold. If I turn all the other radiators off then they get luke warm. Any ideas how to sort this out. Thanks :confused:
One of the radiators is a small double and the other is a large single one!
No work has been done recently.
Its most likely a balancing issue....try search on here for balancing rads if nothing shows up we will write you a new one ;)
unlikely to be a balancing issue as they would work when you turned the others off.
Sludge and or undersized pump
true enough, but they do start getting heat to them....it's just the first thing I'd try. Any work been done on the system recently??
Micro - bore so more than likely a partial blockage in the manifolds possibly moved into pipeork.
more thermostatic radiator valves with their pins stuck :?:
do you have thermostatic valves on the radiators :?:
Good thinking brumylad
But all of them, most unlikely :?:
brumylad said:
true but he only has 2 problem rads
Must be all the excitement the last couple of nights.
you could well be right in that case :oops: :oops:
I don't know what Pro has against trades who hang wall paper, I reckon it could be pretty difficult at times, what with matching paterns, hanging straight, bubbles and ceilings.
Give me pipes, drilling and wires any day.
