Hi folks.
I intend to replace a radiator in the downstairs shower room.
The radiator has a double-entry 8mm valve and I wish to replace the rad with a towel rail which will have standard 15mm through fittings.
I intend to use compression reducer 8mm to 15mm to connect the rail.
Will I have to drain the system to do this? It's a gravity fed system. Probably a dumb question but we all have to start somewhere
