B
Barsteward
No you don't. You are simply posting to try and argue. Stick to plastering.Believe me I know plenty about alarms and I'm asking you where you got the information and why 'mains first'.
Believe me I know plenty about alarms and I'm asking you where you got the information and why 'mains first'. I'm quite capable of understanding the electronics theory on any level you choose - so let's hear it. Why mains - why not battery? (as the manufacturers stipulate).
An expert is someone that follws the instructions for the equipment in use - something that you are failing to do.
To suggest that the manufacturer is giving you advice over the phone contrary to advice in the engineer manual is bizarre.
I ask you again:
What is the benefit of booting 'mains first'?
I expect a technical reply.
Simply saying 'you've been told' is neither convincing nor accurate.
You are advising non-technical posters to work with mains voltages and it simply isn't necessary nor desirable. Now give me the technical reason for your advice - failure to do so will indicate that you have no technical knowledge.
wtf you on about - its standard practise in the pro market
I ask you again:
er - makes the panel work again?
er you saying "non technical posters" cant operate a switch or a fuse? have I said do it with the cover off? (or did I say "take it back to the STATE it was before the power came back on with the dead battery removed.........")
yes very clever Joe - I`m not a software designer or a systems engineer, I`m an alarm installer / service / fault finder so no I won`t be posting a "technical reason" but unlike you I can post advice that helps rather than haunting internet forums squaking on about "whats in the manual.." as if I nievly believed that all the relevant technical information is there like a printed book - it isnt it comes from years of doing these things, you should look at your life again, you waste far too many hours reading forums looking for manuals - get a new hobby you can really excell at, plane spotting?
EXPERT
Almost everyone uses the brakes on their car as per the manual to avoid hitting the car in front... These are expert USERS
Few know how they work... These are EXPERTS
Even fewer know how to repair them... These are USEFUL EXPERTS
Then we get into the world of genius where the expert can write the manual after examining the system and the way it works.
In other words you don't know why you apply mains first. You are just making it all up. Stick to what the manual tells you (if you actually have any manuals) and no-one will get hurt. No panels will be ruined by voltage spikes.
I knew you were a blagger - and your post has proved it.
In other words you have no answer as to why a voltage through a voltage regulator via the mains (all lumpy) is superior to a steady smooth voltage from a battery (as the manuals tell you)
Let's face it - you are way out of your depth here.
