hi all, tnx for your interest:
first rinse cycle not completed
drain light flashes
inlet is clear, i have checked the filter is clear
the flashing drain light stops when start button is held down
machine drains when restarted, but then gets stuck again
disconnected the drain and put into a basin, makes no difference
dw man found the 'H/P switch cover' to be faulty, this likely ?
will cost about 110 to replace ?
what's your call on this ? machine is 2002, so money down the drain and replace the machine, or these mieles go on and on ?
drain light flashes
