Milwaulkee ONE-KEY - future tense or nonsense?
Apps and tools
  • Yay
    Votes: 0 0.0%
  • What's an app?
    Votes: 0 0.0%
  • Total voters
    2
3 Sep 2006
West Mids
Will we be altering the torque of our drills via our phones? Do we need to update our sander's "firmware" via our phone? Does a sander need "firmware"?
Even inventory control is tenuous - nothing an engraver can't do
So will you be buying?
www.milwaukeetool.com/ONE-KEY
Wire free charging? With the lithium battery pack modified to a mobile phone like slim battery pack? Wouldn't work.
The 'lump' battery at the bottom of the impact drill has it's major advantages with the balance of the drill, so how it would work with a slim line lithium battery pack, wouldn't help...
I am yet to be convinced of the benefit of wireless charging, for anything at all. If you're going to be constantly putting your tool down on the charging pad, you need to be close enough to a power outlet to do so. If you're that close to a power outlet, you may as well be using a corded tool. Same for mobile phone charging - you need to be close to a power outlet, in which case it's really not that hard to just plug the USB into the bottom of your phone...
As for Milwaukee Wonky, I'd rather have the settings on the tool than have to keep getting my expensive phone out to adjust it. Means you end up holding two things instead of one. Want to do that while you're up a ladder? No thanks
your gtee is no longer valid as the the fingerprint scanner detected a non certified user
