    Dismiss Notice
Minimum height for new door opening
Discussion in 'Building Regulations and Planning Permission' started by vegasgo, 14 Jan 2019.
  1. vegasgo
    vegasgo
    6 Jul 2004
    111
    Thanks Received:
    Country:
    I'm thinking of knocking out an existing window and bricks below to put in some double patio doors. The height of the existing opening is 198cm - is this too low to meet building regs? Don't really want to raise the height with a new lintel for the sake of a few extra cm but understand there are rules to follow. We already have access to the garden via another door, not sure that would have a bearing on things. Thanks for reading.
  2. Notch7
    Notch7
    15 Sep 2017
    22,846
    Thanks Received:
    1,604
    S. Uplands
    Country:
    Ive never thought about that -is there a minimum height set for an entrance door? -Im not sure there is...
  3. Sponsored Links
  4. ^woody^
    ^woody^
    3 Sep 2006
    32,291
    Thanks Received:
    4,374
    West Mids
    Country:
    No minimum height.
    Dropping the cill down a course may help with perceived height.
  5. lt8480
    lt8480
    2 Aug 2016
    178
    Thanks Received:
    29
    Country:
    No minimum height.
    For reference doors are usually 198-204cm so within the normal range.
  6. Sponsored Links
  7. vegasgo
    vegasgo
    6 Jul 2004
    111
    Thanks Received:
    Country:
    The opening height is 198cm, so would imagine once the door frame is taken into consideration, the door height itself will probably be around 192cm.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
