Next step for me would be to reset, as Terry has mentioned. Post photo of unit, or have a look iirc underneath and there’s a clear label with black writing - this tells you certain information.
For some reason my photos will not load.... I tried holding the high/low pressure button down as well as the on/ off button and it beeped and shut down.
Turned it off and on again at the isolation switch and reset light flashing as well as high/ low pressure button and continued beeping and would not stop so had to turn it off at isolation switch again
Number on bottom of unit Advance 9.0 s
Kohier mira ltd: J97C 15/10
How does it behave if the temperature dial is set much lower?
I have a similar, though older model and if I try to set the temperature too high, it will decide that it can potentially scald, goes to fault condition and shuts down. Powering entirely off, then back on is needed to clear the fault.
That's the one in the picture guys yes.
At first it was just the on/off button but occasionally it's also the hot and cold button too.... Setting the temperature does not make a difference to the cut off......
What would you guys suggest next? Thankyou
Hey guys... So there is no reset procedure in the manual other than fault codes and how to rectify. So i have turned it on and it just shuts down no lights nothing.... I can't find this code or issue.. What can I do now?
Regards
Ian
