I have a Mira Event XS Thermostatic that's been (professionally) installed and working perfectly for at least the last 10 years. I'm the only occupant / user, so usage is relatively light. Recently the motor has sounded just slightly different, and the pressure has been possibly slightly lower, but I really do mean 'slightly' - until this morning, it was running OK this morning for maybe 3-4 minutes, stopped when I turned it off, and then wouldn't start again - in the sense of the on/off button still works, the motor sounds to be running, but no water... only a dribble / drops.
I've just turned the electric & hot / cold water feeds off, and cleaned the inlet filters. A small amount of water (1-2 litres) drained out of the cold water side, but very little from the hot water side (100ml maybe) - both are fed down from the ceiling space. The filters weren't really dirty, and the 'O' ring seals were still good - all cleaned and refitted anyway.
While the inlet filters were out, I cracked each of the isolation valves open, enough to get ltrs/min flow from both sides - they look about equal flow, nice clean water.
Also, while I had the filters out, I checked the resistance across the solenoid coil = 3.7k Ohms (with the wiring still attached, but all electric off).
Restored the water supplies and electric, and tried the shower again - no change. I tried lowering the shower head to ca. 1m below the unit, putting the pump on full speed, and temperature on full cold, and then full hot - no change, still no water after 10 - 20 seconds (didn't like to run it longer with no water).
The motor is spinning, as is the small fan below it, and it varies in speed as the flow control is varied.
Neither the outlet hose (new generic 1/2"), nor the shower head (original), is blocked - I can blow easily through both.
I'm confused at this point:
Is it possible the solenoid is mechanically 'stuck' shut but still measures OK on the coil ? (does that even happen ?).
Thermostat fault ?
Would appreciate any hints or tips anyone might have for further troubleshooting ?
Thanks,
Alan
Thermostat fault ?
Thanks,
Alan
