Have had a problem with the hot water on the combi boiler lately, it's been luke wam. Fitted new Diverter but this didn't solve the problem.
After some more digging I went and isolate the mixer taps in the bathroom, this didn't solve the problem.
But, when I isolated the seperate Hot & Cold feeds to the control unit on the Mira shower the hot water came to life, all and everywhere working hunky dory.
I guess this is where the problem is but am not sure if it's the shower or the cold/hot feed to it and I don't quite know how to find out which.
The isolater valves to the hot and cold shower feeds are now off and the shower not being used obviously. However, I can feel warmth in one of the feed pipes, ( the heating is on but no hot water has been run for a bath a couple of hours prior)
I am kind of hoping that the water warmth is the water in the system from when the bath was run and as the night wears on the pipe will cool, but if it's still the same temperature in a few hours then would I be right in thinking that their is a possibility of when the shower was plumbed in two years ago that they've taken the feed for the hot water from the central heating system?
I would of thought this would have been noticeable as the system has inhibitor in it and when i drain a rad I can smell it and this 4 months after the last amount of inhibitor was put in and so in the case of taking a shower I'm pretty certain that I'd notice inhibitor in the shower when taking one?
I should add that of late the shower has been flaky and a bit hit and miss re hot or not.
Any other ideas?
Any other ideas?
