Missing Fuse
18 Aug 2014
Hi
I have an electric shower that is not heating up and I think its because the fuse is missing from fuse board for it but it is an old fuse and dont know where I can get a replacement or what kw the fuse should be. The other fuse's are wylex.
I have uploaded 2 photos of the fuse board showing mssing fuse to my albums I think it needs to be orange as the other seems to be colour matched.
Any suggestions appreciated
Stephen
I would suggest you don't assume you can just replace the fuse.
There are a few issues arising:
Are you sure the missing fuse feeds the shower and, if sure, ask yourself why the fuse is missing? In other words, why did someone remove it? Was it because there is a fault with the shower.
Needs a bit more investigation IMHO.
B
Hi
thanks for the reply you might be right but just want to get a replacement/old fuse to test it if it works to see if there is electrical problems
Stephen
Please get an electrician to check the installation of the shower BEFORE you replace that fuse.
That consumer unit ( fuse box ) may not be able to supply the power for a shower without the fuse holder overheating and creating a fire risk.
Also there does not appear to be any RCD ( Residual Current Detection ) which are essential with electric showers. They detect that current is leaking to earth and cut the power OFF. If the current is leaking to earth via a person in the shower then the RCD can save a life. ( not always but it gives the person a much better chance of survival )
That fuse position is NOT suitable for any fuse above 30A - and whoever fitted that orange shield in there obviously had no clue what they were doing.
If the cable and shower are in working order, the only option is to fit a separate enclosure with suitable RCD & MCB for the shower only.
However the very fact that the fuse/MCB is missing implies some other severe problem with the cable, shower or both.
