I would like to tile my kitchen using a 3 tile pattern, using 500, 333 and 165mm sq tiles. How big a grout line should I aim for? The lines will be various sizes as the tile sizes don't add up, a 333 and a 165 only give a 2mm wide line if they are next to a 500 tile, my planned pattern is below.
How big a notched trowel should I be using for a mix of sizes.
I think I understand 'back buttering' but not sure why it is needed, if it is for floor tiles? I've never tiled but would want to 'give it a go'!
I'm going to lay some undertile boards down, it may be better in a different post but;
Does anyone advise using the xps type sheets over the cement faced boards? I've read that pro's won't touch them but there seems to be thousands sold so someone must be using them.
I'm going to lay a electric mat so need to use compatable materials, not planning on using the mat just yet so going to put wiring somewhere accessable for later connection.
