Mixer tap leaking from base
11 Feb 2010
Essex
Saw the thread on this. My tap is leaking where the swivel tap sits on the base. on the thread it mentions a small screw, however on my tap there is no screw so how would I take it apart to do the o ring?
Also saw that some can be pulled off? my tap does the full 360 turn. I have tried turning the on off handle past its lock, but it feels like it might break. the on/off handle also swivels like the tap neck but only has about 60 degrees of movement.
Can get a pic, I have manged to get the on/off swivel off via a small screw. it looks like a cartidge (i think!). pics will help as Im stuggling to descibe!
Right - hope this works
Once that comes off will the tap body come off as well? I havnt got a spanner that will undo that, what do i ask for and could i use anything else?
Thanks so far
if i remember i done one before with the end of a tap back nut spanner.
whats the diameter of the hole measure on yours across the flats ?
