Hi All, I've just been approached by a friend whose Mk IV (at least I think it's a Mk IV! It's a '51 plate) Golf is poorly. The driver's window regulator failed and her husband bought a replacement one. Having fitted it, the window can be made to go up and down by applying power to the regulator motor directly. However, now nothing else on the door panel works apart from the little marker light in the bottom corner and the loudspeaker.
The central locking won't work, neither will the electric mirrors. None of the windows, (including the driver's one) will work from the switch panel in the driver's arm rest. I had aquick look. All the wires appear to be connected correctly, and (I'm told) all the fuses are intact.
Any thoughts please?
