Modular Grid Dimmer - anyone recognise this?
8 Nov 2014
Berkshire
I have a modular set of switches for the various lights in the bathroom. Unfortunately the dimmer component has failed and I am struggling to find an identical replacement.
The one I have clips into the frame at the top but has a screw at the bottom. All the designs I can find use clips top and bottom. My electrician fitted it about 2 1/2 years ago.
I will ask if he remembers where he got the parts from but on the off-chance, does anyone recognise the make or style of the dimmer pictured below to give me a clue where I can get one? :scratchchin:
[img]http://thumbsnap.com/s/qlWszVOx.jpg[/img]|http://thumbsnap.com/qlWszVOx
[img]http://thumbsnap.com/s/iHHx7ysI.jpg[/img]|http://thumbsnap.com/iHHx7ysI
Hi, could be Hamilton or Richmond try TLC electrical.
Kind Regards,
DS
Hi Deadshort, someone on another forum has identified it as being part of the Newlec frame system by Newey & Eyre. Problem now is that they don't show a dimmer unit in their catalogue but what I'll do is go to Slough with the dud one in my hand and ask for a replacement. :?
Newey's won't make their own, they will be made by someone else.
Chances are it is Hamilton Litestat. Looks like it.
Try their catalogue.
Its crabtree grid, newlec is the same, any dimmer should fit the grid providing its supplied with a crabtree grid adapter or simply use the adapter from your existing by undoing the nut
Also what are you dimming, that looks like an INDUCTIVE dimmer rather than a normal one.
It also looks like its not correctly connected
Not sure why you say it is inductive, I can see an inductor in it but they are usually just used in series with the supply for smoothing purposes. They are still thyristor driven.
In the past on seeing the VA rating,it would more usually be accociated with inductive dimmers for torroidal trans etc and often more expensive than the basic 400W units suitable for just basic tungsten, halogen use.
Obviously these can still be used to dim virtually anything, I was more concerned the OP may get an alternative dimmer not suitable for his load.
Resistive load dimmers were generally 400W
whereas
Inductive load dimmers were generally 500VA
Crabtree, the switches look the right shape to be as well.
Thanks for all the help chaps, I hadn't realised I could remover the white plastic bit from the actual dimmer. That's useful info. It's dimming 6 x GU10 50w Halogen downlighters.
ETA: Well, I've ordered the ZanoZGRID500 so I will report back on how I get on :lol:
Wow, 300 watts for a bathroom. Glad I don't have to pay your electricity bills.
Can you confirm how that dimmers connected please, it dont seem right.
Rocky, there's only two wires in/out and it's a switch/dimmer so obviously it's the line from the transformer in the loft. I'm just guessing though because it was done by a professional electrician during a full re-fit of the bathroom. On this basis I trust it is correct. The dimmer switches the halogen downlighters, the other two switch some led lights around a mirror and a single downlighter in the shower cubicle which also triggers an integral extractor fan.
