Moduleo LVF
Sound that. Just put lots of weights on top to hold it down while it sticks.
Any thoughts on how long I should let the new concrete slab dry out for before applying dpm and then plywood? Also what glue to use to stick ply to slab
Gripfill will do it or similar.
Concrete will depend how thick it is and drying conditions.
If you put a heavy bucket on the floor and and leave it a hour then move it. If dark the slab is still wet. Or use a moisture meter
Thanks dazlight
But you still think the best option for the slab is to dpm it then self level? And not to use ply?
Like I said mate that’s what I would do but I do it for a living.
But have laid over loads of plywood over the years that builders have done but more can go wrong.
As long as Ply is flat and no movemen5 you will be ok.
Thanks again dazlight. If I measure it with a moisture meter what levels am I looking for?
Thanks again. The slab has been poured today. It will be at least 4 weeks till I can start on the floor. If I apply the dpm does that not stop all moisture coming through to plywood?
It lets some moisture through at a controlled rate. Read the spec on Ardex dpm1c or MVS
Or look at Fball F77 or F78
Hi @nabby68
We are planning to do something similar to you.
Kitchen extension part concrete slap, part suspended timber.
Looking to lay LVT (over Wet UFH, so slight different), 46 Mtr square.
How did yours go?
What approach did you take with glueing etc?
Any tips of lessons you could give?
Stuart
Hi Stuart mine is all layed now. Not sure if you’ve done yours yet but let me know if you haven’t and I can give you some advice and tips
It takes approx a month a inch. All depends on conditions.
Best to lay a liquid Dpm onto the concrete.
