Hi
I took off a downstairs radiator to do some decorating. While this has been disconnected some of the other downstairs rads haven't been getting even warm. I have put the rad back on now, having cleaned it out, and am still having problems.
When I put the heating on the upstairs rads all got hot, too hot to hold your hand against for more than a couple of seconds. All but one of the downstairs rads stayed cold but the other got hot as per the upstairs. I have bled all rads in the house and bled the pump with no avail. The 3 way valve is working and I have hot water.
I tried turning off all the upstairs radiators but the downstairs problem continued for a while. Some of them then started to get tepid-warmish and some stayed cold. I have now turned off all the rads in the house except one. This has now got hot but I can still hold my hand against it comfortably. The thermostat is set to 30c and the pump is set to 3. The boiler cut in to warm the rad but has now gone off again but then cuts in sometime later. The house is no where near 30c more like 12c ish.
I've read through a few years posts and I think I've tried most of the solutions with no success as yet. I am presuming it may be sludge rather than a pump problem. The rads that only get warm at best appear to be consecutive if that helps.
I'd appreciate any help.
