More Hive wiring Help...
4 Oct 2018
Ireland
Hi there,
I'm trying to figure out the wiring from old timer controller to my new Hive Thermostat.
I've an ideal logic heat H18 boiler which has an old timer controller with 4 wires, diagram looks like this:
And in real life this looks like this:
The Hive Wiring diagram seems to be looking for 5 wires:
Old N and L will transfer directly to Hive N and L.
If I transfer
old 1:black -> Hives 1:Common
old 2:brown -> Hive's 3: Heating on
Is that sufficient? (Do I need Heating off?).
Cheers,
Olsiron
What you trying to connect up ? the single channel version ?
oh... good point. I probably didn't think that through.
So yep the boiler supplies heating and hot water. I guess I should be looking at dual channel?
So in that case, should it be:
old:1 -> Hive's 3: Hot Water on
old:2 -> Hive's 4: Heating on
Does 1:Hot Water off and 2:Heating off need to be linked up (to Neutral?)
Cheers,
Olsiron
Yes to live and neutral also 1 and 2 to hives 3 and 4 but I have no way of knowing which is which, you don't need any other connections.
The old controller had a diagram which indicated the correct wire for Hot Water and Heating. All wired up and working! Thanks for your help picasso!
