More pyro in a church
17 Jun 2004
Missing the point just slightly...... :eek:
Oh, and that twin you see going into the board is the supply to the as is doubled in with the supply tails to the main board.
Also whats not shown in the pictures is that roof/ledge you can see below the board in the last pic is the roof of a disabled toilet, the walls are of a timber construction and the installation within this is also pyro. For some unknown reason the cable enters through the back of the panel heater spur k/o box, and when pushed back onto the box the rear of the spur fits pretty tightly to where the cores exit the pot and are bent around
Red is normally only used for fire alarms, but there is nothing to stop you using it for mains or anything else if you really want.
Did you IR test those cables? I can almost guarantee they arn't potted properly, can see them all failing soon too more than likely.
