So I understand, but I think it's true to say that all such requirements/regulations are now "long gone", isn't it?
I've always been somewhat intrigued, and a little concerned, by the labelling requirements. If I recall correctly, prior to the most recent change, ther requirement was for a warning label on an enclosure if it contained conductors with more than a nominal 230V between conductors,
or between any conductor and earth - but that the warning label is now only required if any conductor has a nominal voltage >230V above earth (i.e. warning no longer required for standard 400/230V 3-phase). Is that all correct?
In either case, I've always been 'a little concerned' since the implication almost seems to be that one does not need to take as much care if the PDs one may encounter are 'only' 230V
Kind Regards, John
