Hello,
I recently laid a concrete slab for a shed to sit on top of, however over the longest length (5.5m) there is a 25mm difference in height. I know this is not ideal but I laid this in a day by myself which was quite the challenge.
So to correct the height variation so the walls can sit square I am planning on laying a single course of solid engineered bricks around the perimeter, and making the height difference up in the bed of mortar beneath the bricks.
So taking into consideration the first brick mortar depth at the highest point is going to be roughly 10mm, the lowest point will then be roughly 35mm instead of 25mm.
I have seen so much conflicting information about the type of sand to use and mortar ratios and am looking for some clear advice.
I am not so much bothered about mortar appearance being rough looking or not as its only a single course of bricks, the main thing I am looking for is Mortar Strength up to 35mm depth and brick/ concrete adhesion.
So my questions are:
1. What should the sand cement ratio be, 4:1?
2. Should I use Sharp Sand, Coarse Sharp Sand or Builders Sand or a mixture?
3. Can I use a plasticiser (I bought some today)?
4. Is it okay to lay this mortar on 6 day old concrete as its only a single course of bricks?
5. Do I need to soak engineered bricks?
Thanks,
Antony
Thanks,
Antony
