Looking for quick way to remove mortar from patio and garden wall. Should I go for a multi function power tool, small hand held circular saw (such as a worxs) with a mortar blade or is there a better alternative.
I've got something similar to this somewhere, http://www.faithfulltools.com/p/FAIMMR10
I bought it many years ago for cutting short slots in plaster etc without the mess of an angle grinder, it was OK but a bit slow (and still messy) IIRC.
Hi I have a grinder but it is has a 115mm disc which I think/unhappy to use on the patio mortar though I would be ok using on the wall. was hoping to see if there was a smaller sized dia disc tool to use on the patio not sure if it is poss to get smaller disc for the grinder i have Any ideas? I am well used to using grinders and power tools.
