MOT due Corsair c Airbag light
Discussion in 'Car Repairs / Maintenance' started by Harry4593t, 11 Oct 2021.
  1. Harry4593t
    Harry4593t
    11 Oct 2021
    3
    Thanks Received:
    Country:
    Hey hoping someone has advice for me I've tried changing the pretensioner but the light didn't go out and the corsa onboard scan doesn't say there is anything wrong with the car but the light is still on tried checking the fuses no joy cleaning the connection under the seat, draining the system with the pretensioner unplugged then plugging it in hooking the battery up but the light always goes on and comes right back like a persistent error
  2. Sponsored Links
  3. Keithmac
    Keithmac
    10 Oct 2017
    2,169
    Thanks Received:
    345
    Country:
    You need it plugged in to proper diagnostic kit.
    Some crash flags are permanent, hopefully not yours!.
    • Like Like x 1
  4. Avocet
    Avocet
    30 Dec 2008
    1,138
    Thanks Received:
    153
    Cumbria
    Country:
    As Keithmac says, a lot of safety-critical warnings "latch", so once triggered, you can't easily clear them. Chances are, you've already fixed the fault though. Some higher-end cars have to go to a franchised dealer, who, in turn, has to go to the manufacturer, who has to generate a one-off code, valid for a set number of hours, to put in via the diagnostic equipment to put the light back out, I'm afraid.
    • Like Like x 1
  5. Harry4593t
    Harry4593t
    11 Oct 2021
    3
    Thanks Received:
    Country:
    Okay so then can I bridge out to alternator from the dash board bulb I'm good with working on circuit boards just can't find the pin out for the plug to find the airbag circuit wire
  6. Avocet
    Avocet
    30 Dec 2008
    1,138
    Thanks Received:
    153
    Cumbria
    Country:
    Beyond my pay grade, I'm afraid! I don't know what the airbag light protocol is on a Corsa. Is it supposed to go out with the alternator light or does it stay on longer? I think on quite a few cars, they stay on a bit longer. It'll be down to how well the MOT tester knows Corsas. I think you can buy dodgy emulators on ebay that you connect to the light and it just puts the light on for the correct amount of time. Not sure, really.
  7. Sponsored Links
  8. Keithmac
    Keithmac
    10 Oct 2017
    2,169
    Thanks Received:
    345
    Country:
    Why not fix it properly rather than bodge it?..
    • Like Like x 2
  9. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,347
    Thanks Received:
    2,072
    Hertfordshire
    Country:
    Harry, can't you ask one of your teaches at your college?
    You are training to be a mechanic.
    Andy
  10. thomp1983
    thomp1983
    25 Aug 2016
    335
    Thanks Received:
    40
    Country:
    Try and find someone local to you that has a copy of opcom software, I'm in Nottinghamshire and have a copy of it with a cable.
    • Like Like x 1
  11. Harry4593t
    Harry4593t
    11 Oct 2021
    3
    Thanks Received:
    Country:
    I have a cable just not the software mate
  12. Lazzy
    Lazzy
    23 Dec 2020
    205
    Thanks Received:
    15
    Adromeda
    Country:
    Bouvet Island
    Airbag warning lights are a nightmare
Loading...
Share This Page
