Hoping for a bit of assistance here……
I have a vented indirect central heating system and last week the radiators were heating up with the hot water when the heating was turned off. My first thought was that there was a problem was the three port valve sticking or with the motorised head. I ended up replacing the valve as that was old so could do with changing anyway. Upon re-attaching the motorised head to the new valve the central heating remains on even if the boiler is switched off at the control panel. I believe this normally means that the valve is sticking in the open position but does this mean that the motorised head requires replacing?? On the motorised head you can slide the override control to manual but it won't slide back to auto if the power is switched off, it just slides without resistance in both directions.
Thanks in advance for any assistance.
