'No maintenance'..... But it can leak and you're not bothered if it closes fully.... Maintenance????? Are you bothered?Anyone know where I'd get one cheap?
It doesn't have to be great - it can leak externally and not close fully, but it needs to last a few years with no maintenance.
What's the equivalent UK fluid category?Fluid is clean water.
What do you call expensive?I have manged to find some suppliers online, but they're expensive new.
Do you think that a secondhand one will work out cheaper in the long run?I was hoping there'd be a way of getting a secondhand one.
Do you mean potable water and do you want it to remain potable?
Good point. It's feeding a tank that is used for watering the garden, but it's fed from the pipe that fills the house water tank. So yes, it needs to remain potable. It's looking like a secondhand valve is going to be more trouble than it's worth, since I'll have to know what it's been used for.
It works like this. A borehole pump fills a watertower for the house, and a ground level tank for the garden. When the water stops in the house, someone goes out and finds one of the workers who wanders down and switches the pump on (about half a mile away). After a while he notices that the water tower is overflowing, so he wanders to the garden tank and opens a gate valve in a pipe Td off the main feed. Since the water tower is about 10m higher, all the water now flows into the tank. Sometime later he notices that the tank is overflowing, and he wanders down and switches the pump off.
I've now found this, which looks like it'd do the job:
http://www.valves-online.co.uk/acatalog/copy_of_zzz.html
£230 for a 3" one, does that sound like a good deal?
