Or even more conventionally, use a standard pump-set flow switch and pressure vessel. Like a negative head shower pump.
The pump keeps say over 2 bar in the pipe and pressure vessel.
Use ordinary float operated inlet valves on both the two tanks.
You can feed the garden tank from the water tower if you want, or direct from the pumped line.
The pump turns off when the flow stops.
Why you use a 90mm pipe to fill a garden watering tank I have no idea. The flow through a one inch valve, with 1 bar behind it, is pretty high. Higher if the inlet is connected to the pump outlet.
Why use a garden tank at all? How do you get the water out of it?
