Mounting box earth connection
17 Feb 2007
Staffordshire
Please Help.
I'm currently rewiring some sockets ( converting a single to a double and adding a 3 Amp fused switched spur for a oven hood) and have noticed that the wiring instructions state to connect an earth cable to the metal mounting box. But having checked all the mounting boxes currently in place none have this connection. Is it necessary or can i get away without it?
Steve
Strictly speaking, it is not needed as long as the box has one fixed lug to which the accessory is secured. If your box has two adjustable lugs, then you should fit an earth link to the box.
Having said that, many fit a link anyway.
Are they very old?
Some have a little galvanised screw (not a fixing screw) rather than the brass stud usually seen today.
Hmm. Do you mean none have an earth wire attached to them, or that none have a connection point?
The sockets are new stainless steel and are screwed directly to the mounting box using the screws (galvanised) at either side of the accessory. All the mains cables are connected to the earth terminal on the accessory but the instructions state to have a connection between this terminal and the mounting box.
