Evening All! I am in the process of attempting to mount a cow skin on my bedroom wall, all other internet articles seem to lean towards using lots of small nails however i'd prefer to make a clean and tidy job of it & limit the holes into the skin as it wasn't cheap.
Plan so far : I have stained a length of wood to screw into the wall. The hide is 180cm x 160cm, must weigh at least 8kg and will be mounted horizantally from the top edge (which is far from straight) with the rest left to hang (if possible?).
I have bought from ebay "heavy duty" press studs which are just smaller than a 5 pence peice. The idea behind these was that they would enable me to move the hide easily if i ever wanted to without repeat damage and look nicer than nails BUT i'm unsure how strong they are / how many i would have to use to take the weight? I was planning to araldite the female part of the stud to the wood - would this hold? and/or is there a product such as no more nails which would successfully stick the leather hide to the wood alltogther?
Suggestions & Advice would be greatly appreciated before i go making holes.....
