How would you mount a safe limpet on a safe. They supply 4mm machine screw that need a 4mm drill and tap to make a threaded hole. Tricky to drill safes!!
The limpets we used years ago, were easy, there was a 25mm dia magnet which we used to use Superglue to attached to the safe just make sure you fix the magnet in the right place, so that when put on the Limpet prevents operation of the lock
