Moving a lintel higher up for garage conversion
20 Jan 2013
London
We want to convert our garage into a room and install windows.
It should be straightforward but the only thing giving us a bit of problems is the existing lintel needs to be moved up about 10 cm.
Can I just use strong boys and move the lintel up? Are lintels reusable? The width of the opening is the same
Once the material above the lintel is removed it can be lifted, i.e. re-used as long as the new loads are within the lintels' capacity and are similar in make-up.
What sort of lintel are we talking about, what is the span and what is it doing exactly.
It is holding a balcony which people can walk on. The lintel is at the top of the garage opening. I want to move it slightly higher
Its a car width wide - About 1.5 metres I d say
The loads will be identical
Does BC need to get involved?
What sort of lintel are we talking about?
Steel beam, concrete, pressed steel?
This is notifiable work, yes.
If you garage opening is only 1.5m wide then a garage for a car - it certainly ain't!
